How Do Magnets Propel the Superman Ride at Magic Mountain?
The Superman ride at Magic Mountain uses powerful magnets to accelerate a car and its riders to 42 m/s in 8.1 seconds. The total mass of the car and riders is 4800 kg, resulting in an acceleration of 5.19 m/s². Using the formula F=ma, the average net force exerted by the magnets is calculated to be 24,912 N. The discussion confirms that this calculation is correct, assuming horizontal movement and that the magnets are the sole force acting on the car. The unit of force is clarified as the Newton, equivalent to 1 kg-m/s².
mr.coon
In the amusement park ride known as Magic Mountain Superman, powerful magnets accelerate a car and its riders from rest to 42 m/s (around 90 mi/h) in a time of 8.1 s. The mass of the car and riders is 4800 kg. Find the average net force exerted on the car and riders by the magnets.
my solution:
first i calculated the acceleration which is 5.19m/s squared. then i used F=ma, and that gave me 24,912kg m/s squared. am i correct?
Looks good (assuming the car moves horizontally and the magnet is the only thing exerting a force on it). FYI: The unit of force is called the Newton. 1N = 1 kg-m/s^2.
thanks doc
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
