Non uniformly wound solenoid (no Mag. field?)
  • Context: Undergrad
  • Thread starter Thread starter ifwade
    Field Solenoid Wound
The discussion centers on the significant difference in magnetic field strength between two solenoids constructed with the same wire length (1000ft of 24 AWG) but wound differently. The uniformly wound solenoid produced a strong magnetic field capable of pulling a steel rod, while the haphazardly wound solenoid exhibited almost no detectable magnetic field. This discrepancy is attributed to the potential cancellation of magnetic fields from uneven winding and the importance of maintaining consistent winding direction. The key factors affecting magnetic field strength are the number of turns per unit length and the current flowing through the wire.
  • Understanding of solenoid construction and operation
  • Knowledge of magnetic field principles
  • Familiarity with wire gauge specifications, specifically 24 AWG
  • Basic electrical circuit concepts, including current flow
  • Research the principles of magnetic field generation in solenoids
  • Study the effects of wire winding techniques on magnetic field strength
  • Learn about the impact of current direction on magnetic field orientation
  • Explore methods for measuring magnetic fields, such as using a Gauss meter
Electromagnetic engineers, physics students, hobbyists interested in electronics, and anyone experimenting with solenoid design and magnetic field applications.
ifwade
I made two solenoids using the same amount of wire (1000ft of 24 AWG) around 2 identical bobbins. One of them I painstakingly wound the wire uniformly and tightly. This solenoid is strong enough to pull a steel rod into the middle of the core.
The other I haphazardly wound as fast and randomly as possible to see what the difference in the magnetic field would be. This solenoid had almost no detectable field. The only way I could detect any magnetic force was by holding a compass at one of the ends of the solenoid and the needle did allign itself wih the field.
Should the field be dramatically weaker when the solenoid is not uniformly wound? I fear that maybe I accidently reversed the direction I was winding during the winding process.
Also if the field is dramatically weaker what causes this? I thought perhaps it was because the magnetic fields of each current loop partially cancel out thus weakening the field, but I'm not sure.
Thanks for the help.
The only thing that matters is the number of turns/length and the current.
If you have managed to wind an equal number of turns each way then you won't have a field - you might also have broken the wire and are only getting a very small current leaking the through the insulation.
I see, thanks.
9K
  • · Replies 42 ·
