Why Does Nuclear Fusion Result in Mass Loss and Energy Release?
Nuclear fusion involves the combination of two deuterium (2H) atoms to form helium (4He), resulting in a decrease in rest mass due to the binding energy released during the reaction. The mass of the resulting helium nucleus is less than the combined mass of the original deuterium nuclei, illustrating the principle of mass-energy equivalence (E=mc²). Understanding the binding energy is crucial, as it explains the mass loss and energy production in fusion. The process typically involves multiple steps, including the transformation of protons into deuterium and ultimately helium, releasing energy in the process. This discussion emphasizes the importance of accurate mass values and the concept of binding energy in nuclear fusion reactions.
patapat
In a nuclear fusion reaction two 2H atoms are combined to produce 4He.
(a) Calculate the decrease in rest mass in unified mass units.
(b) How much energy is released in this reaction?
(c) How many such reactions must take place per second to produce 400 W of power?
Honestly, I'm not quite sure where to begin, i think it would help best if someone could explain the the process of the nuclear fusion and why there is a decrease in rest mass. Thanks in advance.
-Pat
patapat said:
In a nuclear fusion reaction two 2H atoms are combined to produce He.
That's pretty much all there is to fusion!
You need to have accurate values for the masses of H and He nulcei then there's an equation you might have heard of ? e=mc^2
well normally hydrogen has only one proton giving it a mass of 1.00794kg. so am i to assume there is a neutron in the hydrogen nucleus?
The font you've written the equations in is a little confusing.
It should say two hydrogen H2 nuclei form a Helium He4 nuclei where the 2 and 4 are atomic masses.
So the Hydrogen here is actually Deuterium with a proton and a neutron in it's nuclei. Note that you will have to lookup the mass of a Deuterium nuclei, you cannot simple add the mass of a proton and neutron because of the very effect you are trying to measure!
One needs to understand binding energy with respect to fusion.
http://hyperphysics.phy-astr.gsu.edu/hbase/nucene/nucbin.html
In the pp-chain, the nuclei of 4 hydrogen atoms, i.e. protons, do combine by virtue of intermediate steps to form the nuclear of a helium atom, or alpha particle. p+p -> d, the p+d -> 3He, the 3He + 3He -> 4He + 2p.
However, the net effect is 4p -> He4 + energy.
http://csep10.phys.utk.edu/astr162/lect/energy/ppchain.html
http://en.wikipedia.org/wiki/Proton-proton_chain_reaction
http://nobelprize.org/nobel_prizes/physics/articles/fusion/sun_pp-chain.html
http://zebu.uoregon.edu/~rayfrey/321/lecture5.pdf
http://burro.cwru.edu/Academics/Astr221/StarPhys/ppchain.html
http://www.astro.virginia.edu/class/hicks/astr348/lectures/lecture4.pdf
