Verifying Nuclear Binding: Is it True and How Far Can it Go?
  • Thread starter Thread starter look416
    Nuclear
Nuclear binding occurs when two nuclei come close enough to bind together, a process that consumes energy. This energy change is linked to mass defect, where the mass of the resulting nucleus is less than the sum of the original masses. The discussion raises a question about the validity of this concept and seeks verification. Additionally, it notes that nuclear fusion is believed to be limited to elements with a proton number of 62 or higher. The information aligns with established scientific principles regarding binding energy and fusion limits.
look416
i had learned that in a nuclear binding, when two nucleus are very close to each other, the two nucleus will bind together, known as nuclear binding.
since the process consumes energy
and from what einstein had proposed, the energy released or used by the nucleus come from their loss in mass, which is known as mass defect.
therefore, mx+my>mafter binding
is it true or not? can someone verify it for me
and also under this info
[edit] Nuclear fusion
Main article: Nuclear fusion
When two low mass nuclei come into very close contact with each other it is possible for the strong force to fuse the two together. It takes a great deal of energy to push the nuclei close enough together for the strong or nuclear forces to have an effect, so the process of nuclear fusion can only take place at very high temperatures or high densities. Once the nuclei are close enough together the strong force overcomes their electromagnetic repulsion and squishes them into a new nucleus. A very large amount of energy is released when light nuclei fuse together because the binding energy per nucleon increases with mass number up until nickel-62. Stars like our sun are powered by the fusion of four protons into a helium nucleus, two positrons, and two neutrinos. The uncontrolled fusion of hydrogen into helium is known as thermonuclear runaway. Research to find an economically viable method of using energy from a controlled fusion reaction is currently being undertaken by various research establishments (see JET and ITER).
it seems that nuclear fusion can only reach up to proton number 62? or higher?
