Object on a plane (equilibrium problem)
  • Thread starter Thread starter ZacBones
    Plane
A 1350kg car is at rest on a plane surface, and the problem involves calculating the normal and friction forces exerted by the car's wheels. The weight vector is given as W = 1350*9.81 j, and the normal force is expressed in terms of its components along the plane's unit normal vector. The discussion emphasizes the need to split the weight into components: one normal to the surface and one parallel to the slope, with the frictional force required to balance the latter. Participants clarify the approach of using component equations to solve for the forces, leading to a successful resolution of the problem. The conversation highlights the importance of correctly interpreting vector components in equilibrium problems.
ZacBones
A 1350kg car is at rest on a plane surface.
The unit vector normal to the surface is: 0.231i + 0.923j + 0.308k.
The y-axis points upwards.
Find the magnitude of the normal and friction forces the car's wheels exert on the plane.
\sum F = 0.
--The weight has the vector W = 1350*9.81i
--The normal force has the vector FN = 0.231|FN|i + 0.923|FN|j + 0.308|FN|k
I also need to express the frictional force as a vector. I know I can find an infinite number of vectors normal to the given vector, but I don't see how I am to choose which is the right one. Mentally, I imagine the car tending to slide "down" the slope relative to its incline, but I'm not sure how to turn this intuition into a vector involving the friction force. Moreover, wouldn't the slide direction depend on the relative strength of the gravitational vs. the normal force?
Even if I found that, I would still need to solve a system of three equations (resulting from setting the sum of components of the force vectors equal to zero). This makes me question my strategy since there are only two unknowns.
I feel like I am missing something obvious here, or that I'm over-complicating the problem. Can anyone clue me into where I am going wrong?
Thanks,
-Zac
First: the y-axis points upward, and the unit vector in the y direction is usually called j. So the weight is W = 1350*9.81 j.
The weight has a component normal to the surface, parallel with the normal of the plane. You can find this component from the scalar product of the weight with the normal vector. This component cancels with FN, the force between the car and the surface.
The other component of the weight is parallel with the slope. You need a frictional force of equal magnitude and opposite sign to cancel it.
ehild
Thanks for the reply. Typically I solve these sorts of problems by solving the system of component equations summed to zero...it didn't occur to me to split the forces the way you suggested.
It also took me forever to remember how to compute the gradient of a plane and then find a line parallel to the plane and following the gradient, but once I did, I was *finally* able to solve for the frictional force.
(Next time I ask something I'll use angle-bracket notation instead of i/j/k in order to avoid typos.)
Thanks,
-Zac
