Ohms law problem
  • Thread starter mujadeo
Calculate the equivalent resistance of the network shown in the diagram. The resistances are: R1 = 12 ohm, R2 = 5 ohm, R3 = 15 ohm, and R4 = 15 ohm.
no prob here
Req = [(1/12)+(1/5)+(1/15)]^-1 + 15 = 17.86ohm
When a battery with E = 6 V and zero internal resistance is attached across this network, what current flows through resistor R1?
Cant figure out if the current thru R1 is actually Req or R1.
When i use V=IR none of the answers come out correct.
Please help
Answers and Replies
Doc Al
Mentor
45,179
1,500
To find the current through R1, find the voltage across it. Hint: First find the voltage drop across R4.
why do i need to know voltage drop across r4?
also does it matter which dorection the current is going?
Doc Al
Mentor
45,179
1,500
Because the voltage across R1 + the voltage across R4 adds up to the total voltage.
No, that just depends on which way the battery was connected.
ok i needed to relearn circuit breakdown and then build it back up.
thanks
Related Threads on Ohms law problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
