How Long Does It Take for an Oil Drop to Travel Between Charged Plates?
The discussion centers on calculating the time it takes for an oil drop to travel between two charged plates, given specific parameters such as distance, electric potential, and the charge of the oil drop. The initial calculations mistakenly used the wrong distance and velocity formula, leading to an incorrect time estimate. The correct distance for the oil drop's transit is 4.5 mm, not 46 cm, and the average velocity should be derived from the acceleration. The proper formula to use is s = (1/2)at², which accounts for the drop's acceleration over the correct distance. The accurate time for the oil drop to travel between the plates is determined to be 0.00324 seconds.
roam
A pair of horizontal parallel plates are placed a small distance, 4.50 mm, apart in air. Each plate is rectangular with a width of 10.0 cm, and length of 46.0 cm. The potential on the upper plate relative to the lower plate is 1.03 × 103 V.
A tiny drop of oil with an excess charge of –1.50 × 10–17 C and mass of 4.00 × 10−15 kg is placed just above the lower plate. The oil-drop is then released so that it is free to move under the action of the electric field.
What time elapses in its transit from the lower to upper plate?
Given:
  • the magnitude of the electrical force it experiences is 3.43-12 N.
  • the magnitude of the electric field between the plates is 229000 v/m.
  • the magnitude of the resultant acceleration of the charge is 858 m/s2
electronic charge = 1.60 × 10−19 C.
P.S. neglect all non-electric effects such as gravity and air resistance.
v_f=\sqrt{2ad}= \sqrt{2 \times 858 \times 0.46} =28
t=\frac{l-0}{v}=\frac{0.46}{28}=0.01642
But the correct answer must be 0.00324 s, why? I can't think of any other way of solving this problem. I appreciate any help!
1) The oil drop needs to travel 4.5mm, not 46cm.
2) Your formula for t would only be true if v was the average velocity, which is not what you calculated. Use the formula s (or d) = at^2 / 2.
-Tusike
