One seemingly easy problem. Please help due soon
  • Thread starter Thread starter intriqet
The astronaut, with a mass of 77.0 kg, must throw a 9.65 kg wrench away from the International Space Station to return towards it, utilizing the principle of conservation of momentum. After throwing the wrench at a speed of 14.82 m/s relative to himself, the astronaut's new speed towards the station can be calculated using the equation m1v1 = m2v2. The correct method involves adding the speeds of the astronaut and the wrench, taking into account their respective directions, to find the speed of the wrench relative to the station.
  • Understanding of conservation of momentum
  • Familiarity with relative velocity concepts
  • Knowledge of basic physics equations involving mass and velocity
  • Ability to analyze motion in different reference frames
  • Study the conservation of momentum in isolated systems
  • Learn about relative velocity and its applications in physics
  • Explore problems involving multiple reference frames in motion
  • Practice using equations of motion in real-world scenarios
Students in physics courses, particularly those studying mechanics, as well as educators seeking to explain concepts of momentum and relative motion.
intriqet
One seemingly easy problem. Please help! due soon!
An astronaut of mass 77.0 kg is taking a space walk to work on the International Space Station. Because of a malfunction with the booster rockets on his spacesuit, he finds himself drifting away from the station with a constant speed of 0.660 m/s. With the booster rockets no longer working, the only way for him to return to the station is to throw the 9.65 kg wrench he is holding.
In which direction should he throw the wrench?
toward the station
He throws the wrench with speed 14.82 m/s with respect to himself.
After he throws the wrench, how fast is the astronaut drifting toward the space station?
What is the speed of the wrench with respect to the space station?
Your response differs from the correct answer by orders of magnitude.
m1v1 = m2v2
The astronaut obviously has to throw the wrench away from the station to be propelled back towards the station. I was also able to find number 2 using the formula above where m1 = mass of the astronaut + mass of the wrench. I am stuck on part 3. My intuition tells me that all I need to do to get this answer is to add 14.82 to the initial velocity of the astronaut but WebAssign will not take the answer. Please help. This is due in an hour and this is the only part of this homework that I am missing
think to begin with that the are together making the equation
(m1+m2) u =m1v1+m2v2
There are 2 frames in your problem: one is space station and the other is astronaut holding wrench.
In this problem, we assume that direction of motion is away from station. It means that velocity of wrench and astronaut holding wrench is positive and velocity of astronaut after throwing wrench is negative.
From problem, we have speed of astronaut+wrench is 0.66m/s (respect to Station => v_SA = 0.66m/s). After throwing, speed of wrench respect to astronaut is 14.82 m/s ( v_AW = 14.82 m/s). To find speed of wrench respect to station, you just plus these 2 speeds: v_SW = v_AW + v_SA.
You may remember that the sign of velocity is depend on its direction respect to your frame.
9K
15K
22K
  • · Replies 36 ·
