Optimizing Velocity for Motion on a Banked Track
  • Thread starter Thread starter mont
    Motion Track
To determine the ideal velocity for an object on a banked track, it is essential to consider the forces acting on the object, including gravity and the normal force, which must be analyzed at the angle of the incline. A free-body diagram is crucial for visualizing these forces and applying Newton's laws in both the x and y directions. The incline affects the distribution of forces, making it necessary to adjust calculations compared to a flat track scenario. Understanding the relationship between the banking angle and the required velocity is key to preventing the object from sliding. Properly accounting for these factors allows for accurate determination of the ideal velocity on a banked track.
mont
An object travels around a circular track with a given radius that is banked/inclined (inward) at a given angle. Find the ideal velocity for the object to travel around the track (so that it does not slide up or down but stays in the middle) with no friction or with a given friction coefficient.
I have no idea how to begin to solve this or where to begin.
Start by drawing a free-body diagram, identifying all forces, and writing Newton's law for both the x and the y directions.
I have done this, but I want to know how i would take the incline of the track into account. The problem would be simple enough if it was on a flat track.
You need to account for the incline to draw gravity and the normal force at the correct angle to each other. Just draw the incline, draw the car, and analyze away.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
