Parabolic Motion of a projectile
  • Thread starter Thread starter wraithseeker
    Motion Projectile
To analyze the parabolic motion of a projectile, key equations include R = (vi^2 * sin(2θi)) / g for range and h = (vi^2 * sin^2(θi)) / (2g) for maximum height. The goal is to determine initial velocity (vi) and direction (θi) based on user inputs for maximum height and distance covered. The discussion emphasizes the need to rearrange these equations to solve for vi and θi. Understanding these relationships is crucial for accurately modeling projectile motion.
wraithseeker
I'm trying to find a equation that will connect a object that is thrown to form a parabolic motion of a projectile. What I want to be able to sub it in is maxheight and displacement covered by the projectile
I don't really know, maybe vi = vf + a*t?
Went to google equations of it and some other sites, I won't list them all here because I searched almost all the sites.
http://www.ac.wwu.edu/~vawter/PhysicsNet/Topics/Vectors/ProjectilesMotion.html
So you want to be able to say simply it's maximum height and its distance covered and find out its initial velocity and direction? Or the other way around?
The maximum height and distance user inputted. Find initial velocity. Direction is calculated already.
Do you mean using R={v_i^2\sin2\theta_i\over g} and h={v_i^2\sin^2\theta_i\over 2g} to get v_i ?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
