Particle dynamics on a cosine path.
The discussion revolves around deriving the equations of motion for a particle traveling along a cosine path influenced by friction and gravity. The user has calculated the motion equations in a moving coordinate system but seeks assistance in relating these to the inertial system coordinates x1 and x2. The motion is compared to a pendulum bob, which also follows a cosine function but experiences damped harmonic motion due to friction. The problem is identified as a classic differential equation challenge. Assistance is requested to bridge the calculations between the two coordinate systems.
gilgtc
Hello, I have attached the problem that I am referring to.
Basically I have a particle traveling on a path defined by a cosine function and I want the equations of motion with respect to the inertial system, if the particle is under the influence of friction and gravity.
I have calculated the equation of motion with respect to the moving coordinate system s but I am not sure how to relate that to x1 and x2 (the inertial system) which is what I ultimately need.
Your help is very much appreciated.
Thank you,
gilgtc
The bob of a pendulum started from height "h" will exhibit motion defined by a cosine function. Because of friction in the piviot the pendulum will not oscillate indefinitely rather it will exhibit damped harmonic motion. I believe this is a classic Differential equation problem.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
