Particle Physics Integral Calculation
Sistine
In calculating the quantum mechanical amplitude for the Coulomb potential (scattering of say \alpha particle off a massive particle of charge Ze), I came across a Fourier transform which I could not calculate.
If
U(r)=\frac{2Ze^2}{4\pi\epsilon_0 r}
then
\tilde{U}(k)=\int U(\mathbf{x})e^{i\mathbf{k}\cdot\mathbf{x}}d^3x=\frac{Ze^2}{\epsilon_0 k^2}
Could you please help me calculate this integral
It looks pretty straightforward, just choose your coordinate system so that \textbf{k} points along the z-axis and perform the integration in spherical coordinates.
Edit: It turns out that the integral doesn't converge directly, so instead you may wish to transform the Yukawa potential \frac{1}{r}e^{-ur}, and then take the limit as u\to 0. Strictly speaking, this is only valid if you treat the Coulomb potential as a distribution and not a mathematical function (otherwise, the limit of the integral need not be the same as the integral of the limit).
Thanks for your reply, I tried integrating over \mathbb{R}^3 but my integral does not converge for 0\leq r<\infty i.e. integrating
\int_0^{2\pi}\int_0^{\pi}\int_0^{\infty}r e^{ikr \cos\theta} \sin\theta dr d\theta d\phi
Doing the \theta integration first I get
\int_0^{2\pi}\int_0^{\infty}\frac{2\sin kr}{k}dr d\phi
But the r integration does not converge. Am I using the wrong limits
Did you read the edit part of my post?
Yes I read the edit part of your post, but in my lecture notes there was nothing said about approximation by the Yukawa potential, the integral was just given as I stated it above. Is the integral an approximation? It partially works out when integrated. (also is it related to the first born approximation?)
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
