rsk2mc
- 26
Hello, I will try and provide as much detail to the problem as I can with the hope someone can help me solve this. We are currently working on a wireless project that contains high electrical currents, because of this the box the electronics are enclosed in experience quite a temperature rise. The basic concept is I have a PCB that is housed inside a copper box, the copper box has 3 layers, outer layer is copper, middle layer is plastic, inner layer is copper. I want to calculate the temperature inside the copper box and outside the copper box.
Here are some details that we know:
The PCB dimensions are: 3mm H x 37mm W x 159mm L
The outer copper box outer dimensions are: 17.9mm H x 41.9mm W x 163.9mm L; wall thickness is 0.2 mm
The plastic box outer dimensions are: 17.5mm H x 41.5mm W x 163.5mm L; wall thickness is 3 mm
The inner copper box outer dimensions are: 15mm H x 39mm W x 161mm L; wall thickness is 0.2 mm
PCB Thermal conductivity: .25 W/m*K
Copper thermal conductivity: 400 W/m*K
Plastic thermal conductivity: .146 W/m*K
bPlastic emissivity: 0.9
Copper wall emissivity: 0.2
Ambient temperature: 20 C
max Temp: 41 C
Power: 7.6 W
Current: .48 amps
Resistance: 33 ohms
i have attached some pictures to help. Please let me know if you have any questions, I have been stuck on this problem.
max Temp: 41 C
Power: 7.6 W
Current: .48 amps
Resistance: 33 ohms
