Pendulum problems - determine speed of the ball
The discussion focuses on calculating the mass, speed, and frequency of a ball swinging in a horizontal circle attached to a string. For mass, the relationship derived is m = (Tcos(theta))/g. The speed calculation was refined to v = square root of gLtan(theta)sin(theta), correcting earlier errors in the approach. Frequency should be derived from the speed using the formula for the period, where period = 2πr/v. The final advice emphasizes using the derived speed to accurately calculate frequency.
logglypop
A ball is attached to a string with length of L. It swings in a horizontal circle, with a constant speed. The string makes an angle (theta) with the vertical, and T is the magnitude of the tension in the string.
1)Determine the Mass of the Ball.
2)Determine th Speed of the Ball.
3)Determine the Frequency of revolutions of the Ball.
1)
F=Tsin(theta)=ma
m= (Tcos theta)/g
2)
F= (mv^2)/a= Tsin(theta)
v^2= [ aTsin(theta) ] / m
v= square root of [ aTsin(theta) ] / m
3)
T= 2pi time square root of (l /g)
frequency= 1/t
frequency= 1/ [ 2pi time square root of (l /g) ]
I need comment about my solution. Thanks
1)
F=Tsin(theta)=ma
m= (Tcos theta)/g
Looks good.
2)
don't you mean F = mv^2/r =Tsin(theta) ? and what is r?
also, your final answer should not have m in it... you should write your answer in terms of the given values of L, theta and T.
3)
frequency= 1/t
Not sure about part 3 (might be right)... I think it's better to use your v value to derive the frequency. try to use the v value along with the circumference of the circle to get the frequency... might come out to what you have above, in which case you've double checked your answer.
I got new approach on number 2
Tcos(theta)- mg= 0
T= mg/[cos(theta)]
F=Tsin(theta)
F= mg/[cos(theta)] * sin(theta) subtitute for T
F=mgtan(theta)
F=(mv^2)/r r=Lsin(theta)
mgtan(theta)=(mv^2)/ Lsin(theta)
v= square root of gLtan(theta)sin(theta)
please give me some advice
Tcos(theta)- mg= 0
T= mg/[cos(theta)]
F=Tsin(theta)
F=mgtan(theta)
Yes, that looks right to me. now use this v value to get frequency in part 3.
period = 2*pi*r/v
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
