How Do You Calculate the Damping Constant for a Spring-Mass System?
To calculate the damping constant b for a spring-mass system, the equation x(t) = Xm e^(-bt/2m) cos(ωt) is used, where Xm is the initial displacement, m is the mass, and ω is the angular frequency. Given the mass of the egg is 0.045 kg, the spring constant k is 24.7 N/m, and the amplitude decreases from 0.290 m to 0.120 m over 5.10 seconds, the values can be substituted into the equation. The angular frequency ω is calculated using ω = √(k/m). The discussion highlights the need for correct substitution of values to find the damping constant b accurately. Understanding the relationship between displacement, time, and damping is crucial for solving the problem.
jaymode
Here is my problem:
A hard-boiled egg of mass 45.0 g moves on the end of a spring with force constant k = 24.7 N/m. Its initial displacement is 0.290 m. A damping force F = - bv acts on the egg, and the amplitude of the motion decreases to 0.120 m in a time of 5.10 s.
I need to find the magnitude of the dampening constant b.
I am completely clueless on how to approach this question.
edit: corrected some stuff.
Me too, since I do not know what you mean by 'the force of B'.
sorry i guess i typed it wrong. the dampening force:
F = -bv
x(t) = x_{m} e^{\frac{-bt}{2m}} cos( \omega t)
b is hte damping force
m is the mass
omega is the angular frequency \omega = \frac{2 \pi}{T} where T = 2 \pi \sqrt{\frac{m}{k}}
for some reason that is not working for me.
perhaps you are not using your numbers correctly
initla displacement Xm = 0.290 m
k = 24.7 N/m
X(5.10) = 0.120 m
t = 5.10s
m = 45g = 0.045 kg
and omega = \sqrt{\frac{m}{k}}
it's blind substitution, really
