Peskin & Schroeder p. 285, change of variables integration measure
naele
I had a question about about the integration measure for the path integral after a unitary change of variables. First they consider a 4D spacetime lattice with volume L^4. The measure is
<br /> \mathcal{D}\phi = \prod_i d\phi(x_i)<br />
They expand the field variables in a Fourier series \phi(x_i)=\frac{1}{V}\sum_n e^{-ik_n\cdot x_i}\phi(k_n). My questions are as follows:
1) Why do they consider the real and imaginary parts of \phi(k_n) as independent variables?
2) Why do they re-write the measure as
<br /> \mathcal{D}\phi(x)=\prod_{k_n^0&gt;0}dRe\phi(k_n)dIm \phi(k_n)<br />
I've never seen a measure re-written like that, I was wondering what allows them to do so.
There's already a thread about this here but I wasn't comfortable bumping a three year old thread, and the response didn't clear up my confusion.
I appreciate any help.
Bear in mind that this is a functional measure. That means that what they're trying to do is consider every possible value that \phi(k) could take on at position k_i. Since the Fourier transform requires \phi to be complex, we need a way to parameterize all of the complex plane. We can do this by defining \phi in terms of two real numbers a and b, by setting \phi(k) = a(k) + i b(k), and integrating both of them over the entire real line, leading to an integration measure of da\:db. Writing d Re\phi\:d Im\phi is just another way of saying the same thing.
I think I understand that part now, thanks. I do have a problem still with the change of variables from \phi(x_i)\to\phi(k_n). I might be missing something, but there would presumably be a factor of V^{1/n} from the 1/V factor in the Fourier series expansion. And then when I transform from \phi(k_n)\phi^*(k_n)\to Re \phi(k_n)Im \phi(k_n) I get a Jacobian that's not equal to 1.
For your first question, I think the answer is that we're just dealing with the measure, not the full integral. So the 1/V will probably show up in the full integral expression.
As for the Jacobian of the measure, that one may have been my fault--I think you need to define the parameterization as \phi = \frac{a + ib}{\sqrt{2}} or something like that in order for the Jacobian to work out correctly.
Well the reason I thought there would be a factor is because, unless I'm doing something wrong, I thought the jacobian for \phi(x_i)\to\phi(k_n) is \frac{1}{V}e^{-ik_n\cdot x_i}. Although now that I think about it, they do say that it is a unitary transformation, so presumably the Jacobian would have unit modulus, but I'm having difficulties checking that.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Thread 'Lesser Green's function'
The lesser Green's function is defined as: $$G^{<}(t,t')=i\langle C_{\nu}^{\dagger}(t')C_{\nu}(t)\rangle=i\bra{n}C_{\nu}^{\dagger}(t')C_{\nu}(t)\ket{n}$$ where ##\ket{n}## is the many particle ground state. $$G^{<}(t,t')=i\bra{n}e^{iHt'}C_{\nu}^{\dagger}(0)e^{-iHt'}e^{iHt}C_{\nu}(0)e^{-iHt}\ket{n}$$ First consider the case t <t' Define, $$\ket{\alpha}=e^{-iH(t'-t)}C_{\nu}(0)e^{-iHt}\ket{n}$$ $$\ket{\beta}=C_{\nu}(0)e^{-iHt'}\ket{n}$$ $$G^{<}(t,t')=i\bra{\beta}\ket{\alpha}$$ ##\ket{\alpha}##...
