Phase Shift in Sinusoidal Functions: Solving for Φ in Different Cases
The discussion focuses on solving for the phase shift Φ in sinusoidal functions using the equation Asin(wt + Φ). Four cases are analyzed, yielding different values for Φ, with some confusion regarding which quadrants these values fall into and whether to add π. Participants emphasize the importance of understanding the sine function's behavior across quadrants and the need to correctly interpret graph intercepts. Errors in initial calculations are acknowledged, with suggestions to consider alternative solutions for specific sine values. The conversation highlights the complexity of determining phase shifts and the necessity of careful analysis of graphs and quadrant positions.
isukatphysics69
Asin(wt + Φ)
let t = 0
Case A:
-.10 = .20sin(Φ)
sin-1(-.10/.20) = Φ = -0.52
Case B:
.10 = .10sin(Φ)
sin-1(.10/.10) = Φ = 1.57Case C:
-.05 = .05sin(Φ)
sin-1(-.05/.05) = Φ = -1.57Case D:
0 = .20sin(Φ)
sin-1(0/.20) = Φ = 0
Now i think i have to determine which ones are in which quadrant. i have to determine whether to subtract pi or not. But how to determine?​
What was the question? No question was stated. Also, the graph is not clear enough to make out anything.
Likes isukatphysics69
here is a better pic
You can see from your graphs which quadrant they are in.
Since you use the sine function, A sin( ωt ), the first quadrant is the section that starts at 0 and rises to A, the second starts at A and falls to 0, the third starts at 0 and falls to -A, and the fourth starts at -A and rises to 0. Equally you can look at the time values: if T is the period, then first quadrant is from t=o to t=T/4, second from t=T/4 to T/2, etc.
Just look at the intercept on the displacement axis and see which part of the cycle it corresponds to.
So i ranked it as c < d < b < a
some of them i thought i would not have to add pi ( i made a mistake in op i think it is add pi) and this was incorrect. some of them are not in any quadrant so there is no no need to add. i added pi to a, and that seemed like the only one that needed it
Your original answers were: A= -π/6 , B=π/2, C= -π/2 and D= 0.
Looking at my diagram, two of these are not correct. What have you now said they are?
Edit: in case you are not familiar with these values;
π = 3.14, π/2 = 1.57, π/6 = 0.53 approx.
b and a were incorrect
not a actually a is correct
i need to just step away from this for a few and go get something to eat
Yeah. I needed to sleep as well.
I disagree with a. (I'll leave the other error for now)
Your calculation sin-1(-.10/.20) = Φ = -0.52 gives one numerically possible result. There is another. You picked the wrong one.
You can see this from the graph -
I've put the origin in the centre and written the phase scale in decimal radians as you used.
You can see that your value of Φ = -0.52 does not correspond with the position of A.
There are two phase angles which give sin(Φ) = -0.5
One is Φ = -0.52 and its aliases 2πN - 0.52 (where N is an integer)
The other is where A is.
Another method you may have used to solve trig equations, implied by your term "quadrant" could be this diagram:
Where you can see that the other solution to Φ = sin-1(-0.5) is Φ = π + 0.52
