Physical Chemistry 1st Law of Thermo
The discussion revolves around calculating the final temperature of nitrogen gas (N2) in two different containers after adding 1000 J of energy. In the first container with fixed volume, the internal energy change (ΔU) equals the heat added (q), allowing the use of the equation ΔU = nCvΔT to find the temperature increase. In the second container with a movable piston, the heat added is converted into both work and internal energy change, complicating the calculation. Participants express uncertainty about which equations to apply and how to account for pressure changes in the second scenario. The thread seeks guidance on these thermodynamic principles to solve the problem effectively.
joseg707
Two containers each contain 0.500 moles of N2 initially at 300. K. One container has a fixed
volume, and the other container has a movable frictionless piston. If both containers are heated
by 1000. J energy, calculate the final temperature of N2 for each container.
PV=nRT
\DeltaU=q+w
Cv for a diatomic molecule is 5R/2
I don't really know how to approach this problem as no pressure or volume is given. For the first container, I realize that the volume is fixed, so no heat is lost to work. I don't really know where to go on from here though. Can I say \DeltaU=q and then set nCv\DeltaT=q=1,000?
For the second container, can I assume that pressure will be held constant as the volume of the container increases? The heat put into the system will then be converted into work as well and so \DeltaU will equal q+w. The temperature will increase, but not as dramatically as the first container. I don't know what to do from here though. I don't know which equation I should start with. If someone can point me in the right direction or correct me if I'm wrong, I'd greatly appreciate it. Thanks in advance!
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
