Solve Physics 2 Lab Problem with Attached Help - Expert Tips Included!
The user is seeking assistance with a specific Physics 2 lab problem, expressing uncertainty about how to approach it. They mention that the link to the problem is not functioning and have also posted the same issue in an advanced physics forum for additional help. The request emphasizes the urgency and importance of receiving guidance. The user appreciates any support offered in solving the problem. Overall, the discussion highlights a need for expert tips to tackle the lab challenge effectively.
carley132
I have the problem attached to this. Any help would be AMAZING. I just don't know what to do for this problem.
Thanks in advance!
link doesn't seem to be working.
i put the same problem up under the advanced physics forum in a doc file also if you wouldn't mind looking there
