Physics Question Regarding Impluse, Momentum, and Velocity.
A hockey puck with a mass of 0.160 kg is subjected to a force of 0.250 N for 2 seconds on a frictionless surface. The impulse calculated is 0.5 NS, leading to a final velocity of 3.125 m/s. The acceleration of the puck is determined to be 1.563 m/s². The final position after 2 seconds is calculated to be 3.125 m. The calculations are confirmed as correct, indicating a solid understanding of impulse, momentum, and kinematics.
Jim4592
I'm not sure exactly sure how to set up this problem...
A hockey puck with a mass of 0.160 kg is at rest at the origin (x=0) on a horizontal, frictionless surface at time t=0, a force of 0.250 N is applied to the puck parallel to the X axis, the force is applied until time = 2.00s.
What is the acceleration, position, and speed of the puck at t=2.00 s
Impulse (J) = (F) * (∆T)
J = (0.250N)*(2.00s)
J = .5 NS
I know J = ∆ Momentum (P) ; and P = Mass * Velocity, but I'm not exactly sure how to calculate what it wants me to find.
Any help will be appreciated.
Thanks,
Jim
You have the force. What does that tell you about the acceleration?
You found the impulse. What does that tell you about the speed at t=2.00s?
Use a little kinematics to find the distance traveled.
I think i get it but aren't completely sure
so using P=mv
.5 NS = 0.160 kg * v
v= 3.125 m/s ?
A = (3.125 m/s) / 2.00s
A = 1.563 m/s^2
and position:
X(final) = X(initial) + V(i)t + 1/2 at^2
X = 1/2 * (1.563 m/s) * (2.00s)^2
X = 3.125m
Could someone confirm that is correct please?
All good!
wow that was a lot easier than i thought. Thanks for your help.
