Find Coefficient of Friction for Physics Final Review
  • Thread starter Thread starter lionsxxden
    Physics
To find the coefficient of friction for the brick, use the equation coefficient = friction force / normal force. Given that a force of 5.4 N is needed to move the brick at a constant velocity, this force represents the friction force. The normal force can be calculated from the mass of the brick, which is 1.2 kilograms, resulting in a normal force of approximately 11.76 N (mass times gravity). Therefore, the coefficient of kinetic friction can be calculated as 5.4 N divided by 11.76 N, yielding a value of about 0.46. This approach effectively applies Newton's Second Law by recognizing that the total forces are zero when moving at constant velocity.
lionsxxden
I'm doing a review for my physics final, and it's asking me to find the coefficient. The problem says,
A brick has a mass of 1,2 kilograms. A force of 5.4 N is required to move the brick across the floor with a constant velocity. What is the coefficient of friction?
What is the equation I use to solve this?
Try and use Newton's Second Law.
I'm assuming this is coefficient of kinetic friction?
coefficient = Friction force / Normal forceAnd when you move at constant velocity, total forces on said object = 0, so can you figure it out from there?
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
