Physics Questions: Electric Field Magnitude/Direction/Units
  • Thread starter Thread starter aaronmilk3
    Physics
The discussion focuses on calculating the electric field at the center of a circle formed by two uniformly charged rods, one positive and one negative. The user believes the electric field's magnitude is zero due to uniform charge distribution, while the direction is thought to be downward, as electric field lines move from positive to negative charges. There is a clarification on the units of electric field, confirming that they are indeed N/C, but can also be expressed in other equivalent forms. The user correctly identifies that electric field lines point away from positive charges and towards negative charges. Overall, the user seeks confirmation on their understanding of these concepts before an upcoming test.
aaronmilk3
I'm review for a test in the morning and just making sure I have this right. The professor did not include a key for the review.
ere is a link to the image for both problems.
In the figure, two curved plastic rods form a circle of radius R in the standard x-y plane.
The charges of the rods are +q and -q on the rods. The charges are distributed uniformly.
What is the magnitude of the electric field at the center of the circle?
A k (4q / (pi R2))
B k (q2 / (2 pi R))
C k (2q / (pi R))
D k (q2 / (pi R2))
E 0
I believe it is 0 because the charge is distributed uniformly across the surface of the field.
What is the direction of the electric field at the center of the circle?
A down (-y)
B up (+y)
C left (-x)
D right (+x)
E 0
Since the top half is the + rod and the bottom half is the - rod I believe it would travel down because the field travels from + to -.
The units of electric field are
A J / C
B J / (C m)
C J / m
D J C
E J m / C
I thought the units of electric field were N/C. Am I overlooking something?
Electric field lines enter charge B while electric field lines exit charge A. The number of
lines entering B equals the number of lines exiting A. The charges A and B are separated
from each other by a distance R. Therefore
A A is positive and B is negative
B A is negative and B is positive
C The magnitude of the electric field is the same everywhere
D The electric field is strongest midway between A and B
E A and B must have the same sign
I believe it is A. A is positive and B is negative because field lines point away from positive charges and toward negative charges.
Let me know if I'm on the right track.
It may be too late to respond, but here are my thoughts.
I don't see the figure you referred to. Do questions 1 & 2 refer to the same figure? If so, how can the electric field point in some direction, but be zero? Or do the questions refer to different figures?
For the units question, you are correct that the units are N/C. But there are other equivalent ways to express that. Use the equivalent units for J in the answers provided, and you should find something equivalent to N/C.
I agree with your answer for the last question, field lines point away from positive charges and towards negative charges.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
