Physics Uncertainity + resistor calculations
The discussion centers on calculating the uncertainty of a 40KΩ resistor with a ±20% tolerance. Uncertainty in this context refers to the potential deviation from the nominal resistance, meaning the actual resistance could range from 32KΩ to 48KΩ. This uncertainty is equivalent to the concept of percent error, which has been previously used in lab calculations. The manufacturer assures that the true resistance will fall within this specified range. Understanding this concept is crucial for accurately interpreting resistor values in practical applications.
neshepard
I am given a resistor, 40KΩ + or - 20%. I know the uncertainty formula but it involves two variables, but not how to combine these together to get an answer. Not to mention, isn't the uncertainty formula redundant since I know the 20% over or under?
I have no attempt as I have no clue where to start. I just need a nudge and the TA is not helpful in the course of three emails.
Nobody has answered yet because you haven't stated what the actual problem to solve is i.e. what you've been asked to compute.
Like the heading says, I'm looking for the Uncertainty in the resistor. Since I have never heard this term, Uncertainty, used like we do in physics class I can only presume it means percent error. But I question even that because in our lab we had to perform percent error calculations on our series and parallel circuits and the volt meter readings versus what the color banding of the resistor would give.
So in reference to your post, my question is "How do I solve for 'Uncertainty' when dealing with a resistor with 40KΩ and +- 20%error?" I have other resistors to work on too, so that is why I said I need a direction to head because this is not a term we used until now.
Uncertainty is exactly what it sounds like -- a measure of how much you could be off in your knowledge of the resistance. In that sense, it is exactly the same as error. With an uncertainty of +/- 20%, it means that the actual (measured) resistance of the resistor could be as high as 20% greater than 40 kiloohms or as low as 20% lower than 40 kiloohms. So you cannot be any more certain about its actual value than that. However, the manufacturer is guaranteeing that the true value will be within this tolerance or range of the nominal (stated) value. Does that make sense?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
