Pipe stress analysis for spring support selection
In pipe stress analysis for additional loops connected to a main piping system, it is crucial to evaluate whether the original analysis remains valid after modifications. The necessity of analyzing both the main and sub-loop pipes depends on factors such as the original system's design, the nature of the modifications, and the expertise of the analyst. It is advised to avoid vague terminology like "small" when discussing pipe dimensions, as this can lead to misinterpretations. Additionally, branches with diameters at least 40% of the main pipe can significantly affect stress results, particularly at the connection points. Consulting an expert may be necessary for comprehensive analysis and validation.
rakeshri28
Dear all,
Welcome to this post.
I have a question. I have a main piping loop around a cylindrical vessel for which stress analsysis is don't and supported properly. Additonal six loops are to be installed in that main loop. This additional weight is coming on the main piping loop. The additional small size pipe loops are connected to the vessel nozzles. We need to support this additional load of pipe and valves. mY QUESTION is: Is it required to do the analysis for the main as welll as sub loop pipes? Or only additional piping loops can be modeled and analysed? Kindly suggest.
If someone did an analysis for a system and you add stuff to that original system, is that original analysis still valid? The answer is maybe. It depends on the original system, the original analysis, the modifications, and the experience of the person making the justification. If you don't know the answer to that, you need to find an expert that can provide that consulting service.
FYI, throwing around relative terms like "small" is not recommended for piping systems.
Dear Sir,
I agree with Jehake.
Would be interesting to have more details and to have a look at the routing. As rule of thumb you can consider that branches can modify stress results if their diameter are at least 40% of the main pipe. There are many schools about this value. Which code are you using (Asme, EN,...)?. By the way one of the weakest point of the small branch could be the branch connection with the main pipe. So you could insert in your model a small part of the main pipe (i.e. till the first stop, but there are other good approches).
If you need more help fell free to contact me at tech@vannella.com.
Best regards.
Corrado Vannella
www.vannella.com
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
