Placement of Magnet in Simple Induction
To induce a voltage in a coil, a change in magnetic flux is essential, which can be achieved by moving a magnet near the coil. The most effective method for inducing current is when a magnet moves through the center of the coil's windings, as this creates a significant change in magnetic flux. However, using a tube-like or sleeve-like magnet with the coil passing through its center can also induce current, but the efficiency may vary. The key takeaway is that while both methods can induce current, the movement of the magnet through the coil typically results in a more pronounced change in magnetic flux, leading to greater efficiency in current induction.
Syed F. Karim
In order to induce a voltage in a coil, is a magnet reqired to pass through the middle of the windings? So the real question is, if I have a tube-like or sleeve-like magnet, can I pass the windings throught the inside of the magnet and still induce a current? Are both ways essentially the same, or is one more efficient than the other?
Greetings !
Welcome to PF Karim ! :smile:
In order to induce a current in a conducting coil
the magnetic flux, which is basicly the magnetic field
per area (<Tesla> or <Gauss> / <ft^2> or <m^2> ), must change.
Now you can move the magnet in any way near the coil
but the most "drastic" change in the magnetic flux
will ussualy occur if the magnet is moving inside the coil.
Of course, you can also "transfer" the magnetic flux
change which occurs when you move the magnet "through" a
conducting core extending inside the coil.
Live long and prosper.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
