Calculating the Velocity of Pin P in a Rod A-Rod B System
The discussion focuses on calculating the velocity of pin P in a system involving two rods, A and B, with specific angular velocities. Rod A is horizontal while Rod B is angled at 30 degrees below it, and pin P moves freely between both rods. The calculated velocity of pin P is 2.4 m/s at an angle of 73.9 degrees down and to the right. Participants express challenges in determining the correct magnitude of the pin's velocity when considering both rods simultaneously. Visual aids are requested to clarify the mechanics of the system and assist in understanding the calculations.
MarkL
From B&J Chap 15
Rods A and B are attached to a wall and point to the right.
A collar with pin P moves freely on Rod A.
Rod A is positioned horizontally.
Rod B is 500mm below Rod A and angled 30 degrees up with the wall.
Pin P is attached to a slot in Rod B. Pin P moves freely in the slot.
Determine the velocity of the pin if the angular velocity of:
Rod A is 8 rad/sec clockwise
Rod B is 3 rad/sec clockwise
Answer : 2.4 m/s, 73.9 degrees down and right
I calculated the relative velocity of the pin for each rod separately.
I get the right direction but the wrong magnitude. Go figure.
I have no problem when the pin moves freely on only one rod.
What is the trick when the pin is free to move on both rods.
Thank you
Mark
Can you give me a picture for illustration ?
Howzziss?..
A Rod A P
]o---------------
500mm /
| / Rod B
B /
]o/
Rod A is a circular rod with a circular cylindrical collar that slides left and right along the rod.
Rod B is more or less flat with a slot cut along the length near the end.
The collar has a pin that fits in this slot. This "connects" the rods.
But the collar/pin combo slide freely along both rods.
As the rods swing, the collar, with P, has a velocity and direction.
Some help?
length of Rod A: 0.5*Tan30 = 0.289 m
length of Rod B: 0.5/Cos30 = 0.577 m
v_ap = (8 r/s)*(0.289 m) = 2.31 m/s -- down
v_bp = (3 r/s)*(0.577 m) = 1.73 m/s -- down and 30 degrees right
v_p relative to B(along slot) due to A = 2.31*cos30 = 2 m/s dwn/lft 30deg
v_p relative to A(along A) due to B = 1.731*cos30 = 1.5 m/s to the right
right direction, wrong magnitude!
My picture didn't work. sorry.
Dave's picture is correct except b crosses a.
Thanks Dave
