Please check -- Looking at phone while driving....
  • Thread starter Thread starter Julie
When driving at 36 m/s (80 mph) and looking at a phone for two seconds, the distance traveled is calculated using the formula s = vt. The solution provided shows that the distance is 72 meters, which is equivalent to approximately 0.045 miles. This calculation is confirmed as accurate by other participants in the discussion. The importance of staying attentive while driving is implicitly highlighted through the context of the problem. Accurate calculations are essential for understanding the risks of distracted driving.
Julie
If you are driving 36m/s (80mph) along a straight road and you look at your phone for two seconds, how far did you travel during this inattentive period?
Please check accuracy of solution
V= s/t s=vt (36)(2) = 72 meters or 72(0.000621371192) = 0.044738725824 mile
[/B]
V= s/t s=vt (36)(2) = 72 meters or 72(0.000621371192) = 0.044738725824 mile[/B]
72 m is correct.
Thanks so much!
