Why Does the mth Interference Maximum Vanish in Single Slit Diffraction?
In the discussion on single slit diffraction and interference patterns, it is established that the mth interference maximum vanishes due to its coincidence with a diffraction minimum. The relationship between the slit separation (d), slit width (a), and the integer ratio (d/a = m) is crucial in demonstrating this phenomenon. The condition for interference maxima is given by dsin(theta) = mλ, while the diffraction minimum occurs at a*sin(theta) = λ. This leads to the conclusion that as m increases, higher interference maxima (2m, 3m, etc.) also coincide with diffraction minima, resulting in their suppression. Understanding these relationships is essential for grasping the behavior of light in diffraction patterns.
slyman
Two narrow slits of width a are separated by center-to-center distance d. Suppose that the ratio of d to a is an integer d/a=m.
Show that in the diffraction patterns produced by this arrangement of slits, the mth interference maximum (corresponding to dsin(theta)=m\lambda) is suppressed because of coincidence with a diffraction minimum. Show that this is also true for the 2mth, 3mth, etc., interference maxima.
My attempt dsin(theta)=m\lambda indicates the conditions for interference maxima, where d is the distance between the two slits. We know that diffraction minimum occurs when a*sin(theta)=\lambda, where a is the slit width. Divide by both equations and we can determine which interference maximum coincides with the first diffraction minimum: d/a=mI don't really understand what the question wants. Could someone please help me out? Thanks in advance.
Please read the posting guidelines and use the template provided. We can not help you unless you first show some effort yourself.
My bad. It's just that this question pisses me off.
Okay, you've almost answered the first part of the question, but you've gone about it backwards.
Let d\cdot sin\theta = m \lambda and d/a=m, then you can show that a \cdot sin \theta = (d/m)sin \theta =.....which answers the first part of the question.
For the second part, how would you proceed?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
