Position of brushes on the commutator in a DC generator
The discussion centers on the placement of brushes on the magnetic neutral axis in a DC generator, which is crucial for effective current reversal. It is clarified that the brushes should be positioned where the coil is perpendicular to the magnetic field, allowing for a change in current direction at the optimal moment. The rationale behind this placement is to ensure that the current flows consistently in one direction through the external circuit until it approaches zero, at which point the brush connection should switch. There is a distinction made between the optimal brush position for motors and generators, suggesting slight variations in their configurations. Ultimately, the goal is to maximize efficiency by aligning brush connections with the point of current reversal rather than maximum emf.
Axe199
i am having a hard time understanding why do we place the brushes on the Magnetic neutral axis, the textbook simply says, because this is where the current reversal takes place, is the point where emf from different meet is the same as the point of current reversal?
If you look at the coil in the magnetic field, you want the current to flow through it in a certain direction in order for the force to turn it in the wanted direction. When the coil gets to be perpendicular to the magnetic field, that's when we want the direction of the force to change. (The side of the coil which was going up, has reached the top and now must come down, etc.) So that's when we want the current to change which way it goes round the coil.
So the brushes must be positioned so that they change connections to the coil, when the coil is perpendicular to the magnetic field.
See this video animation.
Likes jim hardy
I think the motor and generator will differ in the position of the brushes
Likes sophiecentaur
Yes. The optimum phase for switching would probably be slightly different. To minimise the current during switching, it would not be far from '90degrees', for both, though.
I still don't know why we put the brush at the point where the current is 0, we need max output so we should put it where the emf is max right?
Faulty logic there, I'm afraid. When you have max emf, you want to be making use of it all the time. You use it for as long as it is in the same direction - i.e. until it is near zero. The direction of the emf will change after the zero crossing so that's when you want to switch over the connection. Then the current will be flowing in the same direction as before, through your external circuit - whichever angle the commutator is at.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
18K
