Potential across a conducting sphere surrounded by an insulator
7 replies · 3K views
arturo
A conducting sphere has a radius of 2.25 m and carries a positive surplus charge of 35.0 mC. A protective layer of barium titanate is applied to the surface of the sphere to make it safe for laboratory workers nearby. Safety considerations dictate that the potential difference between the surface of the conductor and the outside of the nonconductive layer must be 20,000 V.
How thick must the protective layer be?
Express your answer using two significant digits.
1200 = dielectric constant of barium titanate.
  • Gauss' law for dielectrics:
  • ∫E⋅da = qfree, enc/(εκ)
  • v = -∫E⋅dl
I began by creating a spherical gaussian surface around the object:
EA = qfree, enc/(εκ)
E4πr2 = qfree, enc/(εκ)
E = qfree, enc/(εκ4πr2)
Then I set up the integral for V:
V = -∫E⋅dl
V = -∫qfree, enc/(εκ4πr2) dr
We want the voltage drop from the surface (r = 2.25m) to some R where ΔV = 20,000.
ΔV = -∫2.25R qfree, enc/(εκ4πr2) dr
ΔV =qfree, enc/(εκ4π*2.25)- qfree, enc/(εκ4πR])
20,000 = qfree, enc/(εκ4π*2.25)- qfree, enc/(εκ4πR])
R = 1.32*10-2
Which is incorrect. Any pointers in the right direction would be appreciated.
I think these equations are OK. But I don't get your answer for R. Try solving the first equation listed here for 1/R before substituting any numbers.
Thanks for replying!
Okay, one thing I noticed was I accidentally use the wrong multiplier to convert the charge to coulombs, but I'm still incorrect.
20,000 = q/(4πε0κ) [1/2.25 - 1/R]
.076 = [1/2.25 - 1/R]
.368 = 1/R
R = 2.7 ...
arturo said:
R = 2.7 ...
OK. What did you get for the thickness of the dielectric?
Sorry I got caught up in noticing my mistake with the power of ten that I didn't do it in variables.
ΔV⋅κ⋅4πε/q = [ 1/Rinital - 1/RFinal
ΔV⋅κ⋅4πε/q + 1/Rinital = 1/RFinal
Your comment + typing it out like this I realize that the R I'm solving for is the final radius not the thickness.
so Thickness = 2.7-2.25 = .45 meters
Does this sound correct?
Edit:
Fixed a typo
Yes. I got about .47 m.
ΔV⋅κ⋅4πε/q - 1/Rinital = 1/RFinal
I believe you have a sign error in the second equation. Maybe just a typo.
Re- ran through the calculations got .47 (.465).
Thank you so much for your help. You guys are always great.
Edit:
yeah, just a typo
