Voltage Distribution in a Potential Divider Circuit
In a potential divider circuit, moving the contact X towards point P maximizes the potential difference across the divider. However, confusion arises regarding the impact on connected bulbs, particularly lamp 1. The voltage at node P and the voltage on the slider X when at P are critical to understanding the circuit's behavior. Clarification is sought on the voltage across lamp 1 and the differences between each side of it. Understanding these voltage values is essential for solving the problem accurately.
Muhammad Danish
When we will move the contact X towards P, the potential difference should be maximum across the potential divider. I work out A as my answer but I think it is wrong.
Yes, that is incorrect.
True, but how does this affect the bulbs? What is the potential difference across lamp 1 when you connect X to P?
This is where my confusion is..
@cnh1995 Can you guide me further?
Let's say the battery is 12v.
What is the voltage at node P?
What is the voltage on the slider X when it's at P?
What is the voltage on each side of lamp 1?
What is the difference between each side of lamp 1?
