Power Calculation for Mechanical Component Drives
To determine motor capacity for mechanical component drives, users are seeking reliable calculation resources and reference books. A recommended resource is the downloadable Small Motor Handbook available at Bodine Electric's website. The discussion highlights the difficulty in finding detailed information in existing literature, specifically mentioning Shigley's general mechanical design books. Participants are encouraged to share additional resources or references that could assist in these calculations. Accessing the suggested handbook could provide a solid foundation for understanding motor capacities.
Analysis
Dear all
I need to fix motor capacity for general mechanical components drive apllications
These type of calculation sites if available pl send me the details I cannot find that ones
Any reference books pl.forward me
(I referred shigley.general mechanical design books but i can't find the details)
By
Prakash
Go to
www.bodine-electric.com and look for their small motor handbook. It is downloadable and will get you started.
TVP45 said:
Go to
Thanks for your reply
Let me see the site.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
