Power supplied holding a mass suspended in air
  • Thread starter Thread starter piisexactly3
    Air Mass Power
The discussion revolves around the concept of power in the context of holding a mass suspended in air. Participants are exploring the relationship between force, velocity, and power, particularly when the object is not moving.
  • The original poster attempts to apply equations related to power and work but struggles with the implications of a stationary object. Some participants question the need for power when an object is held in place, while others discuss the distinction between physical work and the energy required by muscles to maintain a position.
The discussion is ongoing, with participants exploring different interpretations of power and work. Some guidance has been offered regarding the application of equations, but there is no explicit consensus on the underlying concepts.
Participants are grappling with the definitions of work and power, particularly in the context of static versus dynamic scenarios. There is a recognition of the physical effort involved in holding a mass, despite the lack of movement.
piisexactly3
A problem I thought would be very simple, but can't seem to get very far with.
Taking equations from textbook: Fv = P . Nope because velocity is 0 however power cannot be 0.
Using suvat: W = Fs , s = ut + .5gt^t , therefore P = Fgt/2 , this seems like the equation for how power would increase as an object falls but not the power supplied to keep it suspended which I imagine would be constant with time.
So there it is, leaving me very fustrated as it seems like it must be really simple.
Yes. Power=Fv and if it's velocity is changing(Accelerating at g), it's power should also change.I don't think I understood you r question clearly. We don't need power,not even energy to hold things in place. Consider a book lying at rest on a table. No work is done there.
Edit. You can still use that equation. Since no distance is traveled when it's suspended, you can just plug in 0 into s in P=Fs/t
Ok but hold 50 kilos out in front of you and tell my why its tiring but no work is being done?
Tiring and work done are two different things.
Our bodies are not efficient. We even get tired sitting somewhere without moving.
Muscle cells in our body need constant supply of energy to stay contracted(Which keeps things lifted up) On the other hand, the table does not deform to keep things above the ground.
  • · Replies 31 ·
  • · Replies 17 ·
