Pressure carrying capacity of a hose
A smaller diameter pipe can withstand greater internal pressure than a larger diameter pipe made from the same material and wall thickness due to the concept of hoop stress. The internal pressure acts on a larger area in the larger pipe, resulting in a greater total pressure force that is distributed over the same wall thickness. This leads to higher stress in the material of the larger pipe. Calculating tangential stresses reveals that the force on the pipe walls equals the force from the internal pressure. Understanding these principles is crucial for evaluating the pressure carrying capacity of hoses and pipes.
Marts12
Hi There,
Why is a pipe with a smaller diameter able to withstand a greater internal pressure than a pipe made from the exact same material and wall thickness but larger diameter?
Thank you
Are you familiar with the concept of hoop stress? Basically, there is more internal area upon which the pressure acts, which means a larger total pressure force. If the wall thickness is the same, that larger force is distributed over the same amount of tubing material, so it experiences higher stress.
Likes anorlunda
Calculate it! Let's do the tangential stresses:
##d## ... inner diameter of the pipe
##l## ... length of the pipe
##t## ... wall thickness
##\Delta p## ... pressure above ambient pressure in the pipe
The force taken by the pipe walls equal the force due to the (over)pressure in the pipe.
Thank you both this is exactly what I needed.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
