Understanding Pressure Drop & Flow in Pipes
The discussion clarifies the distinction between pressure drop due to frictional loss in pipes and the pressure difference that drives flow, particularly in the context of Poiseuille Flow. Poiseuille's equation, while theoretically sound for laminar flow in ideal conditions, is rarely used in practical pressure drop analysis compared to the Darcy-Weisbach equation, which is more broadly applicable. The assumptions of Poiseuille Flow include incompressible, viscous fluids and a constant circular cross-section, making it less practical in many scenarios. However, it is still relevant in specific industries, such as polymer processing, where high-viscosity fluids are common. Overall, understanding these equations helps in analyzing mechanical energy loss in fluid systems.
tonyjk
Hello... I can't find the difference between the pressure drop in a pipe due to frictionnal loss and the Pressure difference that cause the flow like in Poiseuille Flow.. Thanks
They are completely different ideas...what specifically don't you understand about either?
Edit: Oh are you talking about like the losses associated with flows like Poiseuille Flow?
If you are asking how this solution to pressure drop is associated with similar ideas such as the Darcy-Weisbach equation, the answer is that the analytical (experimentally derived) Darcy-Weisbach equation is employable under broader circumstances.
The assumptions taken for Poiseuille Flow equations are (from wikipedia) "...that the fluid is viscous and incompressible; the flow is laminar through a pipe of constant circular cross-section that is substantially longer than its diameter; and there is no acceleration of fluid in the pipe". In theory this is a nice equation to look at to understand where the mechanical energy is being lost to, but in practical applications of pressure drop analysis it is rarely, if ever, employed.
Basically: Poiseuille equation is theoretical, solutions like Hazen-Williams and Darcy-Weisbach are analytical.
we say that gradient pressure cause flow but in pipe flow the pressure different is due to friction loss
To see how people generally use these equations (Poiseuille is mentioned in there), see http://www.kimberly.uidaho.edu/water/papers/others/Allen_1996_Trans_ASAE_Relating_HazenWilliams_and_DarcyWeisbach.pdf
A solution to Poiseuille's equation is used to approximate the D-W friction factor for Laminar, fully developed flow in long pipes.
Thank you i understand it
In polymer processing applications, typically involving high viscosity polymer melts (say 1000 Poise), the Poiseuille pressure drop equation is used extensively. This includes the entire man-made fiber industry, polymer granule production industry, and plastics manufacture industry. In addition, it applies to flow of ordinary fluids through capillaries.
Thanks for that, I wasn't aware it was so widely used in that industry. I've never personally had any experience with such high viscosity fluids.
