Pressure in a Fluid: Same in All Directions?
  • Thread starter Thread starter physgrl
    Fluid Pressure
The pressure in a fluid at any point is the same in all directions, as confirmed by the discussion. While one participant initially believed pressure increases upward due to greater depth, it was clarified that pressure is calculated by multiplying depth by fluid density. This results in uniform pressure exerted in all directions at a specific depth. The concept that pressure acts equally in all directions is fundamental in fluid mechanics. Understanding this principle is essential for solving related problems in physics.
physgrl
2. The pressure in a fluid at any point is:
a. greater upward
b. greater downward
c. greater laterally
d. the same in all directions
n/a
I thought the pressure was greater upward because it is greater at greater depth, but the answer key says its the same in all directions. can someone explain why?
Pressure is computed by multiplying the depth below the surface by the density of the fluid. At that specific depth, pressure is exerted in all directions and it is the same in all directions.
Ohhh because the point has no area
Yes!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
