Calculate Pressure in a Star at Center
  • Thread starter Thread starter Irid
    Pressure Star
To calculate the pressure at the center of a star using the density function ρ(r), one must consider the gravitational force and the resulting pressure equation. The initial approach led to an infinite pressure result due to a missing limiting procedure and the assumption of constant density near the center. The correct method involves integrating the mass function M(r) and applying the structure equation dP/dr = -GM(r)ρ(r)/r². This equation can only be integrated exactly for a few simple models, making numerical methods necessary for realistic scenarios. Thus, understanding the integration process is crucial for accurately determining central pressure in stellar models.
Irid
Given the density function \rho = \rho(r) calculate the pressure at the center of a star.
F = \frac{GMm}{r^2}
P = \frac{\Delta F}{\Delta A}
Choose some radius r. Then the gravitational attraction there is
\Delta F = \frac{GM(r) \Delta m}{r^2}
and the resulting pressure is
P = \frac{\Delta F}{\Delta A} = \frac{GM(r)}{r^2} \frac{\Delta m}{\Delta A}.
We can interpret \Delta m as the total mass above radius r and A as the area of the sphere at that radius. Then
P = \frac{GM(r) [M_0-M(r)]}{4\pi r^4}.
Near the center
\frac{M(0)}{4\pi r^3} \approx \rho_c/3
and so
P(0) \approx \frac{G\rho _c M_0}{3r} \rightarrow \infty.
Where's my error?
Don't you need to bring in the density function \rho(r) into this in order to deal with M(r)? It seems a bit mysterious how you got a result out of
<br /> P = \frac{GM(r) [M_0-M(r)]}{4\pi r^4}
I didn't get a result, I got an infinity, which I don't like. I skipped a limiting procedure in my derivation. Since I'm looking for the pressure at the center, very near to the center I can assume that density is constant with value \rho_c, so the mass out to a small radius \Delta r is
M(\Delta r) \approx \rho_0 4\pi/3 (\Delta r)^3
If you plug this in, there remains one more power of a small \Delta r which causes the infinity.
The relevant equations are dP/dr=-GM(r)*rho(r)/r^2, where dM(r)/dr=4*pi*r^2*rho(r) and M(r) is the total mass contained within radius r. So you can see immediately that dP/dr -> 0 as r -> 0. So there's no singularity at the origin. But to get the central pressure you have to integrate the M(r) first and then do the integral to get the pressure. I don't think you get get it by using only the total mass and properties at the center.
I can confirm that an approach working from
confuses the issue. The appearance of a singularity is only due to the fact that the M_0-M(r) is concealing a factor of r^3 (M_0 is not just a constant), so the dimensions for the quotient are G\rho^{2}r^{2}, which has units of pressure.
The structure equation
\frac{dP}{dr} = -\frac{GM(r)\rho(r)}{r^2}
can only be integrated exactly for a handful of cases, unfortunately, so there are only a few simple models where you can calculate a straightforward result for the central pressure. In realistic situations, the integration is performed numerically.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
