Pressure vs speed for liquids ?
In a horizontal pipe with varying diameters, fluid velocity increases in narrower sections due to the principle of conservation of mass, which states that the product of velocity and cross-sectional area remains constant for incompressible fluids. This results in a higher speed of fluid particles in the narrower section compared to the wider section. According to Bernoulli's equation, as fluid velocity increases, pressure decreases, indicating an inverse relationship between speed and pressure in liquids. The pressure difference is what drives the fluid to flow faster in the narrowed area. Understanding these principles clarifies the dynamics of fluid flow in varying pipe sizes.
furkang
pressure vs speed for liquids ? :(
Think of a pipe positioned horizontally.
Some fluid is flowing from left to right.(e.g. water)
Right side of the pipe is well narrower than left side.
Is the speed of a fluid particle at the right greater than the speed of a particle at the left?
What about their pressures?
(Perfect world no energy loss)
OR
perhaps I can NOT make such a comparison without considering any value constant.
I am really confused please help , basically I am looking for an example which prooves inverse proportion of speed and pressure of LIQUIDS. Can you give me an example like mine? Thank you for your help...
Let's assume an incompressible fluid - the density does not change - and apply conservation of mass.
\rho_1 * V_1 * A_1 = \rho_2 * V_2 * A_2
for incompressible flow \rho_1 = \rho_2 = \rho
which then leaves V_1 * A_1 = V_2 * A_2
So what does the say about the relationship between fluid velocity (speed) and area?
ok that's well ...
that means fluid flows faster in the narrow section. That is completely different from my thought.
Is it the same if we use Bernoulli's equation to see that?
I could't see where is the pressure difference
Considering the fluid is incompressible, helps by making density constant. Is it the pressure difference, that causes the fluid to flow faster at the place where the pipe narrows?
You should take it the other way round(you should obviously apply Bernoulli's equation), that static head drop occurs due to increase in velocity head.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
