Can You Explain Pressure Differential Between Heat Exchanger Sides?
In summary, the question is whether it is possible to get water into the nitrogen side of a heat exchanger when there is a high pressure of nitrogen gas on the shell side and low pressure of water on the tube side. The answer is yes, as long as there is a way to bring nitrogen to the other side or use an external power supply. The temperature difference does not matter in this case. However, if water needs to be let out to go to the nitrogen side, the volume must be filled with nitrogen or the volume must be reduced using external power, which can be gained through an expansion of the nitrogen side.
charlie95
32
Pressure ?
If you have a heat exchanger. On the Shell side you have nitrogen gas at 35 bar, and on the tube side you have water at 5 bar.
Is it possible to get water into the nitrogen side?
I know the answer is yes, but I do not understand why. Is there someone who have a simple explanaton for this?
If you bring some nitrogen to the other side at the same time or use some power supply, it is fine. I don't see the relation to a heat exchanger: Where is a temperature difference?
temperature do not matter in this case. I only wanted to know if you have gas at high pressure on one side of heatexchanger/cooler/heater and water at low pressure one the other side if there is possible to get Liquid into the gas phase? temperature do not matter in this case.
See above:
Water is (reasonably) incompressible so it would it take much nitrogen leaking into the water side to equalise the pressure?
Probably not, but if you want to let water out (to go the the nitrogen-side), you have to fill the volume with nitrogen or reduce the volume with external* power.
*can be gained by an expansion of the nitrogen-side.
Related to Can You Explain Pressure Differential Between Heat Exchanger Sides?
What is pressure differential?
Pressure differential refers to the difference in pressure between two points within a system or between two different systems. It is measured in units of force per unit area, such as pounds per square inch (psi) or pascals (Pa).
What causes pressure differential between heat exchanger sides?
The pressure differential between heat exchanger sides is usually caused by a difference in temperature. As hot fluid flows through one side of the heat exchanger and transfers heat to the cooler fluid on the other side, the temperature difference leads to a difference in pressure between the two sides.
Why is pressure differential important in a heat exchanger?
Pressure differential is important in a heat exchanger because it helps to drive the transfer of heat from one side to the other. The greater the pressure differential, the more efficient the heat transfer process will be. Additionally, monitoring pressure differential can also help to identify any potential issues or malfunctions in the heat exchanger.
How do you measure pressure differential between heat exchanger sides?
Pressure differential can be measured using a variety of instruments such as pressure gauges, manometers, or flow meters. These instruments can be connected to both sides of the heat exchanger and the difference in pressure can be calculated. It is important to ensure the instruments used are appropriate for the type of fluid and temperature range in the heat exchanger.
What factors can affect pressure differential in a heat exchanger?
Several factors can affect pressure differential in a heat exchanger, including the flow rate and viscosity of the fluids, the size and design of the heat exchanger, and any obstructions or blockages within the system. Changes in any of these factors can impact the pressure differential and therefore the efficiency of the heat exchange process.
  • Thermodynamics
  • Mechanical Engineering
