Probability that a chip is operative
  • Thread starter Thread starter SamTaylor
    Probability
To calculate the probability that a chip with twenty transistors is operative, it is necessary to consider that the chip functions as long as no more than three transistors fail, with each transistor having a failure probability of 0.1. The correct approach involves using the binomial probability formula to sum the probabilities of having 0 to 3 failures. The initial calculation was deemed reasonable, as having more transistors increases the number of combinations that can lead to the chip still functioning despite failures. The discussion highlights the importance of understanding how the number of components affects overall reliability.
SamTaylor
A chip contains twenty identical transistors, which are connected in such a way
that the chip will perform its function provided that no more than three of the
transistors have failed. The probability that any given transistor has failed
equal 0.1. Calculate the probability that the chip is operative.
\sum_{n=0}^{3}\binom{20}{n} 0.1^{n} (1-0.1)^{20-n}
But this can not be right since the probability that the chip is still working
is higher with less transistors but with the same failed number.
20 transistors p = 0.8670
10 transistors p = 0.9872
Can someone give me a hint please.
I didn't check your calculations, but your approach is correct. Your result is actually reasonable. When you have 20 transistors, there are many more ways to have up to 3 fail than when you have only 10 transistors.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
