Can the problem about relative motion be solved without using calculus?
The discussion revolves around solving a problem from Serway's textbook regarding relative motion, specifically part c, without using calculus. The original poster attempted a calculus-based solution but seeks an alternative method as presented in the book. Participants suggest that the solution involves analyzing the combined velocity vectors and ensuring the angle between them is optimized for minimum downstream distance. A vector diagram is recommended to visualize the relationship between the stream and boat velocities. The conversation concludes with the original poster gaining clarity on the approach and considering the suggested method.
issacnewton
I have posted the problem and and the solution of part a,b,c in file 1.doc. This is problem
from ch. 4 of serway. It doesn't yet assume calculus. I have question about the part c.
I did it using calculus. but the book's solution uses the kind of arguments which i am not able to understand. Is it possible to solve the part c without using calculus.
thanks
  • 1.doc
    1.doc
Hi IssacNewton,
thanks
Yes, part c can be done without using calculus. Please show your attempt and I or someone else can help you.
hi al
I think the combined velocity has to make the minimum angle with the direction which is perpendicular to the stream... in that case we can guarantee that the distance traveled downstream will be minimum... but I don't see how to avoid calculus again...
thanks
IssacNewton said:
hi al
thanks
That's right, and another way to say that is that the combined velocity you are looking for is the one that makes a maximum angle away from the stream's flow.
So what are all these possible combined velocities? I would suggest when you draw your vector diagram, draw the stream velocity first, and then think about adding all possible boat velocities (the speed is set, so you can only vary the boat's velocity angle) to that. What do you get?
There are still a few more steps; does that help?
hi al
yes , basically we have to increase the angle of combined velocity vector with the stream velocity vector... I see what you are saying... now the diagrams given in my attachment are making some sense...so basically we fix the tail of boat velocity vector to the tip of the stream velocity vector and then rotate this boat vector, so that the combined velocity vector makes maximum angle with the stream velocity vector...I see where the argument is going...let me think on these lines...
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
