Finding Acceleration and Stopping Time in a Multi-Block Lifting System
The discussion focuses on a multi-block lifting system involving two hanging blocks and a third block on a surface. The acceleration of the blocks is derived as a function of their masses and gravity, resulting in the expression a = (m1 + m2)g / (m1 + m2 + M). For the system to remain stationary under static friction with a coefficient of μs = 1.00, the difference in mass between m1 and m2 must be less than or equal to 100 kg. When the system is moving at an initial speed of 2.00 m/s and kinetic friction is applied, it takes approximately 0.292 seconds for the system to stop, calculated using the coefficient of kinetic friction μk = 0.700. The calculations and expressions provided are essential for understanding the dynamics of the system.
ChrisBrandsborg
A lifting system can be modeled as two blocks of mass m1 and m2 hanging from two pulleys, connected by ropes to a third block of mass M = 100 kg, lying on top of a horizontal surface. There is gravity g = 9.80 m/s2.
a) Ignoring at first friction, find an expression for the acceleration of the blocks, as a function of the masses and gravity.
b) Now, we assume that the system starts at rest, and that there is static friction between the block M and the surface it is lying on. How much diffe- rence in mass can m1 and m2 have, for the system to not start moving, if the coefficient of static friction is μs = 1.00? Provide an expression as well as a numerical value.
c) Next, we assume that the system is moving with an initial speed vi = 2.00 m/s, when suddenly kinetic friction between M and the surface is triggered (the brakes are switched on). The coefficient of kinetic friction is μk = 0.700. How long does it take for the system to stop if m2 = m1 = 100 kg ? Provide an expression as well as a numerical value.
ΣF = ma
F* = F
(Newton´s laws)
I think I did a correctly, but I have some problems solving b.
I put positive direction downwards to the left.
a) Firstly I separated the system into 3 systems:
1) am1 = m1g - T1
2) am2 = T2 - m2g
3) This one is the third block, lying on the top of the surface.
am3 = T1 - T2
then add together:
so that: a (m1 + m2 + m3) = m1g - T1 + T2 -m2g + T1 - T2
a = (m1 + m2)*g / (m1 + m2 + m3)
b)
I know that μs = 1.00.
Fs = nμs = mgμs = 100kg * 9.80 * 1.00 = 980N
That means that m1g - m2g = 980N
Then divide by g:
m1 - m2 = 100kg
Is that the answer? That the difference in mass has to be less or equal to 100kg?
b)
Then divide by g:
m1 - m2 = 100kg
I tried c as well:
vi = 2.00 m/s
μk = 0.700
How long does it take for the system to stop?
Fk = ma
μkmg = ma
a = μkg
v = vi + μkgt
t = vikg
t = 2.00/0.700*9.80 = 0.292s
Correct? Or do I have to use the masses as well? m1 = m2 = 100kg?
