- #36
DrClaude
Mentor
- 8,386
- 5,474
They are, but the strings are moving.gracy said:I thought charges were at the ends of string.
I thought So ,they are not at the ends of string.Doc Al said:The string is 3 meters long. Start out with the charges 1 meter apart
Yes they are, as in the picture.gracy said:I thought So ,they are not at the ends of string.
Sure they are.gracy said:I thought So ,they are not at the ends of string.
How?op mentions two strings whereas @Doc Al took one string in his exampleDrClaude said:No, he was just rephrasing the same problem, with number values for the length of the strings.
You have already been given a significant amount of guidance and several helpers have asked you questions which would guide you in the right direction if you tried to answer them. Instead, you are ignoring these questions thinking that they cannot possibly have anything to do with your problem. If you are going to have any chance of resolving this issue, you need to start listening to what people are telling you.gracy said:could you Please guide me further.
I am trying my best.You would have definitely agreed if you were to see my rough /practice book.What else I can do.Orodruin said:You have already been given a significant amount of guidance and several helpers have asked you questions which would guide you in the right direction if you tried to answer them. Instead, you are ignoring these questions thinking that they cannot possibly have anything to do with your problem. If you are going to have any chance of resolving this issue, you need to start listening to what people are telling you.
gracy said:I don't know whether it is correct but i think tension force will be able to be split into one horizontal force and one vertical.The horizontal one would cancel the repulsive force.But one problem with this is then vertical force would be unbalanced so net force would be vertical so motion should be in vertical direction.
gracy said:l (lower case L)cos theta =kq^2/d^2
here d=distance between the bodies when horizontal component of tension cancels the repulsive force.And k is coulomb constant having value of 9 multiplied by 10^9.
It has been a long thread.What's the use?How many helpers are there,is not something that matters.A student needs approval ,corrections.gracy said:as if bodies were attracting each other
gracy said:This suggests r=2l
I want to know how to find "r"how r came out to be 2l?
Doc Al said:Sure they are.
DrClaude said:But that string could look like the two in the OP.
The charges would be like the charges at the ends of string of length 2lDrClaude said:What does the system of charges and strings look like if r=2l?
So how do you go from two charges attached to strings of length ##l## to the two charges being ##2l## apart?gracy said:The charges would be like the charges at the ends of string of length 2l
Angle will increase until it is 180 degrees?DrClaude said:So how do you go from two charges attached to strings of length ll to the two charges being 2l2l apart?
Yes!gracy said:Angle will increase until it is 180 degrees?
Because of repulsion between like chargesDrClaude said:Can you see now why this is happening?
Don't forget the tension in the string.gracy said:Because of repulsion between like charges
This vertical force is responsible for going from two charges attached to strings of length l to the two charges being 2l apartgracy said:I don't know whether it is correct but i think tension force will be able to be split into one horizontal force and one vertical.The horizontal one would cancel the repulsive force.But one problem with this is then vertical force would be unbalanced so net force would be vertical so motion should be in vertical direction.
Seeking your "yes" in answer to my post #56 to be satisfied.DrClaude said:Are you satisfied that you understand the answer to your question "I want to know how to find "r"how r came out to be 2l?"
Yes. When the two strings become horizontal, there is no more vertical component of the force, and equilibrium is reached between repulsion and tension.gracy said:This vertical force is responsible for going from two charges attached to strings of length l to the two charges being 2l apart
And after that tension in string would be equal to the repulsive force which has the value of (1/4πε0)*q^2/4l^2
r being 2l
Right @DrClaude ?
We not all in the same time zone, and I need to sleep from time to timegracy said:Seeking your "yes" in answer to my post #56 to be satisfied.
