Problems that I got wrong and still don't understand
  • Thread starter Thread starter jst
The discussion focuses on various physics homework problems related to electric fields and forces. The first problem involves deriving the electric field at the center of a charged arc, with the correct equation being E = (kQ)/(2R). In another problem, the direction of the Coulomb force on a charge in an equilateral triangle configuration is clarified, confirming that the force on charge #3 is directed towards "B." Additional problems address the relative lengths of electric force vectors and the placement of a third charge to achieve a specific net force, with correct answers provided for each scenario. The final problem calculates the electric field strength between two point charges, yielding a result of 0.0788 MN/C.
jst
Before my discovery of this forum, I tried to do some homwork with not help...well, I got a few wrong and will be having a quiz soon...so I got to correct a few of my old mistakes :rolleyes:
Given a uniformly charged arc with radius R and total charge Q. The arc subtends a total angle of 90 degrees. Derive an equation for the total electric field at the center of curvature of this arc in terms of R,Q and the Coulomb constant k.
http://glomawr.com/phy-hw-01-02.jpg
I'm not sure
I put: (kQ^2)/R^2 , which was not the correct answer
_________________________________________________________
Given: two charge diagrams each consisting of three charges arranged in an equilateral triangle. Each charge has the same magnitude of charge, q. Force directions are labeled A through L spaced at 30 degree intervals. What is the direction of the Coulomb force on charge #3 in Diagram A?
http://glomawr.com/phy-hw-01-04a.jpg
I put "B" and was correct, but I'm not sure my logic was correct.
Given two charges aligned horizontally. Initially both charges have an equal charge -q. The electric force on the right charge is shown having a magnitude of one. In the diagrams below changes have been made to the situation. For each diagram A,B, and C, state the relative length of the electric force vector on the right charge.
http://glomawr.com/phy-hw-01-08.jpg
I put: A half, B 4, C 4
The correct was: A 8, B 4, C half
Given: Two point charges of charge +q and - q aligned horizontally. The positive charge feels an electrostatic force F. Five points along the horizontal axis are labeled as shown A through E. To what point could a third charge +q be placed so that the net electrostatic force on the positive charge is 3F?
http://glomawr.com/phy-hw-01-09.jpg
I put A, but the correct answer was B
Given: Two point charges of charge 7.00 nC and -7.00 nC aligned horizontally. The charges are separated by a distance of 8.00 cm. What is the electric field strength at point B halfway between the charges?
http://glomawr.com/phy-hw-01-10.jpg
I did:
(8.988*10^9)*(7*10^-9)/(.08/2) +
(8.988*10^9)*(-7*10^-9)/(.08/2)
=0
Which was wrong, the solution was:
.0788 MN/C
Given a uniformly charged vertical line and a uniformly charged thin half ring with their axes of symmetry aligned horizontally as shown. The total charge on the line is Q. The total length of the line is 2.00 m and the half-ring radius is R = 1.00 m. At a distance x = 1.00 m to the right of the line charge is the center of curvature of the half ring. What is the total charge on the half ring if the total electric field at the center of curvature is zero? (You will need to integrate over the half ring. S = R(theta) and dS = R(dtheta) and dq = (charge per length)(dS)
http://glomawr.com/phy-hw-01-11.jpg
I some how came up with: 3.84Q
But the solution was: 1.11Q
I appreciate any help with any/all of these.
Thanks,
Jason
For the first question, the equation for the total electric field at the center of curvature is E= (kQ)/(2R).For the third question, the correct answer is B because Coulomb's Law states that the force between two charges is in the direction from positive to negative, so the force on charge #3 in Diagram A is in the direction "B".For the fourth question, the correct answer is A: 8, B: 4, and C: 1/2, as the electric force vector will be 8 times as long on A than C. This is because the force between two charges is inversely proportional to the square of their distances, so the electric force vector on A is 8 times as long as the electric force vector on C.For the fifth question, the correct answer is B because the net electrostatic force on the positive charge is 3F when the third charge +q is placed at point B. This is because the net force on the positive charge is the vector sum of the two individual forces, so when the third charge +q is placed at point B, it will equal and cancel out the force from the negative charge, resulting in a net force of 3F on the positive charge.For the sixth question, the equation for the electric field strength at point B is E = (kQ)/(4x^2). Plugging in the given values, you get E = (8.988*10^9)(7*10^-9)/(4*1)^2 = 0.0788 MN/C.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
