Projectile Equation Help: Finding Velocity for Water Thrown at 60 Degrees
  • Thread starter Thread starter reisada
    Projectile
The discussion focuses on calculating the initial velocity required for water to hit a flower located 5 meters away when thrown at a 60-degree angle. The participant utilized parametric equations of motion, specifically x = v0cos(θ)t and y = v0sin(θ)t - 0.5gt2, to derive the necessary calculations. After manipulating the equations and solving for time, the final calculated initial velocity (v0) is determined to be 7.6 m/s. This solution effectively addresses the projectile motion problem without considering air resistance.
  • Understanding of projectile motion principles
  • Familiarity with parametric equations in physics
  • Knowledge of trigonometric functions (sine and cosine)
  • Basic algebra for solving equations
  • Study the derivation of projectile motion equations in detail
  • Learn about the effects of air resistance on projectile trajectories
  • Explore the concept of maximum range in projectile motion
  • Investigate real-world applications of projectile motion in engineering
Students in physics courses, educators teaching projectile motion, and anyone interested in solving real-world problems involving angles and distances in projectile dynamics.
reisada
english is not my native language , ill do my best
someone wants to throw water to a flower that is to the distance of 5 m and at the same level as the place where the water comes from. air resistance doesn't count
what is the velociity of the water so that it hits the flower, if the water is thrown with an angle of 60 degrees from the horizontal?
already put the parametric equations of the movement :
x=xo + voxt
y=yo+voyt-1/2gt^2
but now i can't do anithing else!
and i can't find any way to find the velocity of the water( the inicial one i think)
anione can help fast please? thanks a lot
Are you able to write down the equations of motion for a projectile in terms of s, u, v and t?
These are the standard equations one uses to solve such problems
If you can do this, then you need to be able to split the motion into horizontal and vertical components and solve from there.
Let me know how much of that made sense
well first of all let me repost :D
the parametric equations are :
x=vo*costeta*t
and
y=vo*sinteta-5t^2
then when vo*costeta*t=5, , when 5 is the reach, we can find the vo
vo=5/0.5t
but now how can i find the time for this equation? am i going well?
aha , now ill try to do the position/time which is:
r(t)= vocostetat ex + vosintetat - 5t^2 ey
now if i find the zeros of this function i can get the time right?EDIT : damn this way i still don't know the vo...
ok so i restarted the exercise and now i got an answer, can you guys please try to see if this is the correct answer? because this exercise is not from any book with solutions
so this is what i did:
x=vocos60t
y=vosin60t+5t^2
vosin60t+5t^2=0 ( when it is vertically at the same spot as the flower)
t=0 and t= 0,173vo
then
x=vocos60*t
0,5vo*0,173vo = 5 (when x is 5, i calculated the vo)
vo = 7,6 m/s
what was your answer please answer this is really making my mind go crazy :D thanks in advance
19K
