Projectile Motion of a Pebble on the Sloping Faces of Pyramid Cheops
A tourist throws a pebble from a height on the Pyramid of Cheops, with the pebble's initial speed directed perpendicular to one of the pyramid's sloping faces. The discussion focuses on deriving equations for the pebble's motion, considering both x and y directions. Participants suggest drawing a sketch to visualize the problem and emphasize the importance of calculating the pebble's trajectory using trigonometric functions. The equations discussed include relationships involving initial velocity, angle, and time to determine where the pebble will hit the pyramid. The conversation highlights the need to equate the height equations to find the point of impact accurately.
joemama69
a tourist is climbing high up the pyramid of cheops, which has sloping faces that make and angle of theta with the ground. The tourist throws a pebble with initial speed v is a direction perpendicular to one of the faces. the the height at which the peble hits the pyramid below the tourist
y = vo + vyt + .5at
y = vtsin(90 - theta) + 4.9t
what else can i plug in. I am lost
joemama69 said:
1.
y = vo + vyt + .5at
The above equations are wrong. Check them.
y = vo + vyt + .5at
Draw a sketch of the problem. Think both in the x and y directions as you write your equations. The pebble will have a constant velocity in the x direction of ____? Given that info, you can calculate how far down the face the pebble will hit as a function of time.
Then think in the y direction, and write an equation that describes the height y above the launch point the pebble will be as a function of time. Equate the two y's, and that's where and when the pebble will hit the face...
vx = vcos(90-\theta)
vy = vsin(90-\theta)
x = vocos(90-\theta)t
is this usefull tan\theta = y/(vcos(90-\theta)t)
it seems i have 4 variables, x,v,t\theta can i get a clue on how to eliminate them
ok made some progress but still a little confused
x = vtcos(90-\theta) therefore t = x/(vcos(90-\theta))
y = vsin(90-\theta))(x/(vcos(90-\theta))) - 4.8(x/(vcos(90-\theta)))
y = xtan(90-\theta)) - 4.8x/(vcos(90-\theta))) projectile
now i found the y based on the angle
tan\theta = -y/x, therefore y = -xtan\theta so i set both y's equal
-xtan\theta = xtan(90-\theta)) - 4.8x/(vsin\theta)
is this correct so far
