Projectile motion launched rocket
A rocket is launched at 75.0 m/s at a 60.5° angle, aiming to clear an 11.0 m wall located 22.5 m away. Initial calculations for horizontal and vertical components of velocity yielded values of 36.93 m/s and 65.276 m/s, respectively. The time to reach the wall was calculated as 0.609 seconds, leading to a vertical position of 39.75 m at that time. However, the acceleration due to gravity was not accounted for, resulting in an incorrect final clearance of 28.75 m. Including vertical acceleration is crucial for obtaining the correct answer in projectile motion problems.
PhilCam
A rocket is fired at a speed of 75.0 m/s from ground level, at an angle of 60.5° above the horizontal. The rocket is fired toward an 11.0 m high wall, which is located 22.5 m away. The rocket attains its launch speed in a negligibly short period of time, after which its engines shut down and the rocket coasts. By how much does the rocket clear the top of the wall?
V0x= V0Cos (angle)
V0y= V0Sin (angle)
x=1/2at(squared)+V0t
X(t)=vt
To solve this problem I first used the first two equations to find the V0x and V0y. I ended up with 36.93 for x and 65.276 for y.
From there I used the 3rd equation considering that acceleration (a)=0 so I ended up with x=V0t or 22.5=(35.93)t. I ended up with .609 seconds.
From here I used the last equation (considering that acceleration is constant) and found that Y(t)=V0y(t) or y(t)=65.276 x .609.
My answer was 39.75. I subtracted 11 from that and ended with 28.75 which is not the correct answer.
Thanks.
Thanks.
Note that though you knew that there was a y-acceleration, you forgot to include it in your
calculation :wink:
Oh, thanks so much!
I was thinking "this problem is not this hard, how do I keep screwing up..."
