2 Projectiles are fired simultaneously
  • Thread starter Thread starter Om Swostik
    Projectiles
Two projectiles are launched simultaneously from ground level with the same initial speed and cover a horizontal distance of 160m, but one lands 6 seconds before the other. The motion is governed solely by gravitational acceleration, g=10m/s². The angles of projection for the two projectiles are complementary, with one at theta and the other at 90 - theta. The participant attempted to equate their ranges and times but struggled with the resulting trigonometric equations. Further assistance is requested to solve the equations derived from the problem.
Om Swostik
2 projectiles are fired simultaneously from ground level with same initial speed (u).Both cover same horizontal distance of 160m on reaching the ground level .One of them reaches 6 sec prior to the other.Only gravitational acceleration g=10m/s squared governs the motion of both the projectile.Calculate u.[/B]
Range(horizontal distance)=u squared sin 2×theta/g= Ux cos theta ×time
Time=2u sin theta/g
Where ,
U is initial velocity
Theta is the angle of projection
and T is the time taken by the projectile to reach ground level.
Note:vector u has 2 components which are Ux=u cos theta and Uy=u sin theta
Time=2u sin theta/g
Where ,
An attempt is required. Forum rules.
Likes jfnn
THE ATTEMPT AT A SOLUTION:
I took the angle of projection of 1st projectile as theta and the angle of the 2nd one as 90 - theta (as there can be two angles of projection for the same range).
I equated the range and the time ,that is
T=t+6.As I have really limited knowledge of trigonometry, the resulting equation which I arrived at couldn't be solved by me.
Please post the equation. It might save time to post your working too, in case you have a mistake somewhere.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
