What Equations Are Used in Projectile Motion Calculations?
Projectile motion calculations involve key equations that account for the effects of gravity and horizontal motion. The vertical motion is influenced by a uniform downward acceleration due to gravity, while the horizontal motion maintains a constant speed. To find quantities such as velocity and maximum height, appropriate kinematic equations should be applied separately to each component. Combining the results from both the vertical and horizontal components allows for comprehensive analysis of projectile motion. Understanding these principles is essential for solving projectile-related problems effectively.
Pratheepa
hi,
can some one help me with projectile??its a general question..what are the equations do we use to do a sum with projectile??to find velocity??maximum height??and other stuff..
please help me as soon as possible...
For a projectile, the only force acting is gravity, which acts downward. So the vertical component of motion is characterized by having a uniform downward acceleration while the horizontal component of the motion has constant speed. Use the appropriate kinematic equations for each component and then combine them to find any quantity of interest.
