What Determines the Velocity Extremes in Projectile Motion?
  • Thread starter Thread starter kamalpreet122
    Theory
In projectile motion, the velocity is at its maximum just before impact and at its minimum at the peak of the trajectory when the launch point is lower than the landing point. Conversely, when the launch point is higher than the landing point, the velocity is maximum just before landing and minimum at the peak. As the projectile rises, its speed decreases until it reaches maximum height, after which it increases as it falls. The discussion emphasizes understanding these concepts without considering air resistance. This foundational knowledge is crucial for grasping the dynamics of projectile motion.
kamalpreet122
My physics teacher last year did not teach us anything about projectiles i had to learn everything by reading from textbooks. I tried finding the answers to these questions but couldn't think of anything so if some1 could please help me and explain the why behind the answer.
A.) For a projectile with the launch point lower than the landing point, in what part of the flight is the magnitude of the velocity at a maximum? a minimum?
B.) In what part of the flight is the magnitude of the velocity at a maximum and in what part is it at a minimum, for a projectile with launch point higher than the landing point?
Another name for "magnitude of velocity" is speed. As the projectile is rising, is its speed increasing or decreasing? After the projectile reaches maximum height and starts coming down, is its speed increasing or decreasing?
Answer these questions and you will see how to answer A and B.
Since it is high school physics, are you assuming there is no air resistance due to drag on the projectile?
yes we'r ignoring air resistance and hmm it makes a lot more sense now LOL man my brain works slow.. =| thnx a lot :-)
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
